Lake Pipes
Old 06-08-2006 | 07:16 PM
g.chinn2's Avatar
Lake Pipes
I bought triple lake pipes, they came with a type of long C CLAMP WHICH CROME AS THE PIPE IS ,HAS ANYONE USED THIS TYPE .
Old 06-08-2006 | 09:24 PM
SoCalHHR's Avatar
Generally not, as those types of chrome band mounts can be seen. Most of our customers have them mounted by a muffler shop where they are welded on from the backside. This makes for a strong, sturdy mount and cannot be seen unless you're under the car.
Of course the band type will work, but I'm not sure how or where you would attach them?
Here's a "How-To" for the way we do it:
Old 06-08-2006 | 10:01 PM
cj krause's Avatar
I used the clamps of course, cause i am different.
there is a curve and a ridge in the channel. i put a 3 in long sheet metal screw there and then a smaller 2 in on the body toward the inside.
did that on front and back so 4 screws holding it in place
the pics arent that great and i was having to do them w/o a lift.
Old 06-09-2006 | 04:54 PM
g.chinn2's Avatar
Thanks From G Chinn
Old 06-09-2006 | 05:35 PM
SoCalHHR's Avatar
See - that CJ knows his stuff!
Glad you got the info you needed...
Old 06-09-2006 | 06:45 PM
BlackHHR's Avatar
I have a question about the Laker pipes. I know that the rear hole is capped, but can you take the two front ones off. Maybe cut them off to have the tree holes on each pipe. I love the look of the triple lakers, but if you can't get all the holes working for the exhaust than I'll stick with getting the slant tip pipes.
Old 06-09-2006 | 06:50 PM
SoCalHHR's Avatar
The rear outlet is part of the whole length of pipe. The other two outlets bolt-on and do not have openings to the pipe itself. If you want to make your side pipes functional, I would recommend going with the Slant Tip Ovals.
Hope it helps,
Old 06-09-2006 | 09:39 PM
BlackHHR's Avatar
Thanks Mike.
Old 06-11-2006 | 10:54 AM
g.chinn2's Avatar
Thanks From G Chinn
pyro panel
16
06-01-2010 01:06 AM
pyro panel
11-05-2009 05:44 PM
sweetmama
04-14-2007 10:29 PM
hotrodharley
03-30-2007 09:27 AM
