Paint on OEM GRILL
Paint on OEM GRILL
Lets say I was to paint my oem grill..... what preperation(s) would I need to do? Does paint stick to chrome?
I did learn from my Road Ripper paint jobbie that unless properly prepared, the paint adhesion is NOT very good. I realize we are talking different surfaces here, principal is the same though.
I seek input! (forgive not using the seach button)
Lots of prep sanding and sanding in between coats. The chrome is over white plastic so I would either prime it or use a plastic adhesion promoter for a base. Clear coat after of course. Thinking of matching the grille white?
I know its off the topic Sindy but saw a car carrier full of white and spring edition HHRs today driving home from work. Could not get a great look but that white looks sharp. It was just nice to see HHRs on the road still have not seen many in this area. The dealerships are not moving them real fast around here it seems.
Originally Posted by deadhead
.... saw a car carrier full of white ... Could not get a great look but that white looks sharp.
Mine should arrive any day now! I'm exercising for my happy dance for when the call comes through from my dealer! Cart-wheels and farting rainbows!
Now - lightly sand down the entire white grille with #1500 again! Once it is good & ready, start in with your 1st clear coat. Wait till tacky and repeat again 2 more times. 3 coats of clear will add to the shine and help protect from road chips. Allow to cure - off the car - for at least two days. Keep indoors at night and put it in the sun on the second & third days to aid in curing.
That's how I'd do it!
Hope it helps - and I can't WAIT to see it on your new WHITE HHR!
id take it to a bodyshop because:
1.there is a special prep they can do for plastic that will allow paint to adhere better to it (had my avalanche done)
2. that grill will see alot of abuse from head on rain to rocks and bugs, a body shop would commit to guarenteeing it to stay on
