Advice needed
Advice needed
I pulled the passenger door panel off. All the pins separated OK except one, it took out the part that is supposed to stay in the door (the yellow piece). No big deal, but I can't separate the two pieces. Nope, I tried everything I could conjer up in the old shop, they ain't coming apart. It looks pretty simple, but nothing I can think up can separate these two pieces. I have pulled on them to the point of breaking. Anyone know how to get them apart? I guess I could just pop it back in whole, but its supposed to come apart like the others.
Use a 90 degree pick, and gently lift the yellow retaining flaps towards the point of the plug while you apply releasing pressure. Or, put the whole unit back in the door, and use your panel puller claw to pry it out, with the curved side keeping the receiver in place, while the claw pulls the door pin out of it.
