I got my front headrests off
I finally decided to look into it a little bit and get them off.
you have to push this tab in on both front headrests to come out completely. My tool of choice was a golf ball mark repair tool. worked perfectly:
And the reason I wanted them off:
it depends what you want from it...I have no other opinion because its the only tune ive tried. it completely changed the car. with the automatic tranny, i can push the pedal to the floor at 25mph and light up the tires. colder temps i can lose traction in 2nd gear. i could never do that without the tune. the boost builds so much faster. ive seen it peak at 22psi or so. stock its like 16-17psi. the low end power is so much better with the programmer. Like i said, its a totally different car with the programmer. this is my review from when i bought it....
https://www.chevyhhr.net/forums/2-0l-performance-tech-46/superchips-review-39222/
Lethal Tendencies
10
01-24-2010 07:34 PM
