Mods - Interior Discussion related to the looks of the interior of the HHR.
Looking for lighting ideas.
Old 02-21-2015 | 09:39 PM
Danman03's Avatar
I've been replacing all my interior lights with LEDs for more brightness, but one area I can't get enough light to is the cargo area. Has anyone found a lighting mod that will light that area up? I've thought about maybe trying to find junk light housings and seeing if I can find a place to mount them. I've also see where users have flipped their dome lights 180 degrees, but I don't think that will solve the problem. Any ideas?
Old 02-21-2015 | 09:42 PM
Don't know what year you have, but my 2010 has 2 rear dome lights. Plenty of light for me.
Old 02-21-2015 | 09:54 PM
Danman03's Avatar
Probably should have mentioned that. I have an 07 Ls. Just the single dome light with 2 push lights that point over the backseats and the other light points to the cargo area. I'm looking to put lights in the actual cargo area.
Old 02-22-2015 | 09:42 AM
A couple of LED lights on either side mounted into the side panels might do the trick!
Old 02-22-2015 | 01:36 PM
Danman03's Avatar
That's what I'm thinking. Is there a way to wire it up for the lights to come on when the doors open? Would I have to tap into the dome lights?
Old 02-23-2015 | 10:59 AM
Tap the dome lights or run a switch at the tail gate
Old 02-23-2015 | 07:55 PM
Danman03's Avatar
I think I'm going to try to find some type of small light housing and put them in the plastic paneling on both sides of the boot. I'll just wire up a switch, because I don't know how to tap into the dome lights and I don't really feel like ripping up the headliner, which is probably what would happen.
Old 01-29-2016 | 02:38 PM
Norcaldunk's Avatar
I used 12v 'fairy lights' that I found on e-bay. I just tucked them between side panels and the headliner, in several places to keep them in place. They plug into a 12v outlet, then I connected a 12v led dimmer, again from e-bay,. The dimmer is located between the doors on the passenger side. I can light the entire rear compartment, back seats and cargo area, from a faint glow to bright enough to read by. Cost about $10.
bowtieboy68
Mods - Exterior
12-14-2014 11:31 AM
GEMP
10-04-2012 03:02 PM
jvdjgjm
09-29-2011 07:02 PM
Seeburg220
03-30-2008 10:15 PM
buz1953
17
02-26-2007 09:26 AM
