Mods - Interior Discussion related to the looks of the interior of the HHR.
Looking to paint my Pillars but needs some advice.
Old 06-29-2011, 09:37 PM
xzombiex66's Avatar
Yeah, you wouldn't be able to sand this stuff because of the texture. Wax and grease remover and self etching plastic paint would be your only option. I'd go with the Krylon mentioned earlier by lunchbox.
yeah i cleaned em with acetone...
xzombiex66 is offline
Old 06-29-2011, 09:47 PM
stanvalp's Avatar
just a thought, but would it work lightly sand blasting them to roughen the surface. that would get into all the crevices.
stanvalp is offline
Old 06-29-2011, 09:48 PM
stanvalp's Avatar
also, what happens if the interiour has been armour-all'd
stanvalp is offline
Old 06-29-2011, 10:21 PM
Chad- wow, & they didn't get gummy ? acetone is pretty strong for plastics.
stanvalp-
I think a light sandblast is way overkill..
& to remove armorall, just need a wipe down with grease & wax remover, or alcohol, or similar..
sleeper is offline
Old 06-29-2011, 10:29 PM
desertdave's Avatar
use a gold scotch brite from a body shop supply store with a plastic cleaner then use plastic adhesion promoter.goodluck
desertdave is offline
Old 06-29-2011, 10:41 PM
I agree, but this plastic seems pretty stout. A quick cleaning with acetone probably would be fine. (obviously if Chad just did that very thing) I think you would have to soak the parts to really mess them up.... But yeah, most plastics and acetone don't get along well.
Greybeard999 is offline
Old 06-29-2011, 10:54 PM
xzombiex66's Avatar
Didn't use much acetone at all, worked perfectly.
Old 06-29-2011, 11:02 PM
Silverfox's Avatar
I don't know why you couldn't Scotch Brite it with a very mild pad.
If you use your fingers instead of your hand you can get into the impossible spots that sanding can not get to without creaming the top off of everything.
Also use a circular motion with the Karati Kid "wax on wax off" technique.
One direction and then the other direction.....
If your lucky you can lightly use Acetone but it can be risky and not neccesary here IMO.
Silverfox is offline
Old 06-29-2011, 11:48 PM
xzombiex66's Avatar
Here is out it turned out, I love them, turned out great tweeters look awesome and sound so much better. Forgot to take before pics installed im sure i can find some on here some where though.
Before
After
Installed (yes crappy pic but its dark and i was using my phone..)
Old 06-29-2011, 11:57 PM
Very Clean end result..
What did you use for paint, satin finish ?
sleeper is offline
Quick Reply: Looking to paint my Pillars but needs some advice.
