Need Dimming/Compass Mirror Wiring Diagram
Does anyone have this. I picked up a auto dimming/compass mirror at the junkyard. I've figured out a couple of the wires, but would like to know what the rest control so I can get as many things work work factory as possible. If you could just tell me what the color codes are.
I have the mirror without onstar, just a "N"orth button in the bottom center and maplights on the bottom.
Thanks.
Thanks.
Here are the pinouts for the DD8 inside rearview mirror. The info is direct from the Chevy Service Manual. I've omitted the info for the OnStar.
Pin Wire Color Function
1 GY Interior Lamp Control
2-5 Not Used
6 D-BU/WH Courtesy Lamp Supply Voltage
7 Not Used
8 BK Ground
9 L-GN Backup Lamp Supply Voltage
10-12 Not Used
13 PK Ignition 1 Voltage
14-16 Not Used
Sorry - the forum software pretty well trashed the text formatting. Hope this helps!!
Tomk
Mpls, MN
2-5 Not Used
7 Not Used
8 BK Ground
10-12 Not Used
14-16 Not Used
Tomk
Mpls, MN
Robecon
"How To" Tutorial Library
11-20-2014 11:57 PM
Garmel
08-29-2014 05:50 PM
