06 lt jerking
06 lt jerking
after driving a short distance with A/C on or off and come to a complete stop car kind of jerks a little and rpm's jump a little but not much any idea what this could be
thanks nick
thanks nick
If the AC is running it's probably the compressor cycling on and off...... compressor puts quite a load on the engine and you will feel the difference between engaged or disengaged. If everything is smooth without the AC running then this is more than likely what you are feeling and I would say is normal for the car.
My 06 did that, and others have complained as well. There never did seem to be a fix, and if it is the same as others including myself experienced it will not get any worse.
