06 will not turn over
Old 01-21-2011 | 03:35 PM
hhrluvr's Avatar
Hey guys,
I was wondering if anybody had this happen to them;
I turn the key on and everything lights up. Then I turn it to start and "nothing"
fuses are good, no engine lights on dash, battery is good.
here is the catch.
if I wait 4-8 hours it will start. shut it off and try to start it and nothing again.
getting frustrated.
thanks for any help.
Brian
Old 01-21-2011 | 03:38 PM
Rod Run's Avatar
How do you know the battery it good?
Old 01-21-2011 | 04:06 PM
HHR GUY07's Avatar
you need to have the battery tested ill bet it has a dead cell in it i had a colorado that did that too the battery was bad.
Old 01-21-2011 | 05:04 PM
Laco's Avatar
Originally Posted by hhrluvr
Hey guys,
here is the catch.
getting frustrated.
Brian
My guess would be, the key program is not always read reliably. Why, I don't know, but I would get it checked before you wind up stranded somewhere.
Old 01-21-2011 | 08:20 PM
hhrluvr's Avatar
at this point i cannot drive it anywhere because i know what its going to do.
i will remove the battery and have it tested, but i will put up a bet this isn't it.
no clicks, slow starting, dimming etc?
starts when it decides too???
After having the software flashed with the updates when i bought it a year ago to just pass emissions.
this doesn't surprise me.
thank you all for your time and input.
Old 01-22-2011 | 12:23 AM
X 2 Good thing to check.
Old 01-22-2011 | 11:30 AM
Lucky's Avatar
Heres a shot in the dark. check the relays it the fuse center under hood make sure they are all pushed in all the way. also look for the starter relay and swap it with another one from the center. I swap the starter relay with the horn relay. if it still wount start then you have ruled out a bad relay.
Old 01-22-2011 | 09:01 PM
Don06's Avatar
Do you have remote start? See if that works. If it doesn't, you eliminate the key as the problem.
Old 01-22-2011 | 11:19 PM
hhrluvr's Avatar
remote start acts the same way as the key.
thanks for mentioning that.
hhrluvr's Avatar
thanks for the suggestion!
I will look into that and try it out.
Quick Reply: 06 will not turn over
