08 HHR electrical
08 HHR electrical
Does anyone have a link or a source to an electrical diagram for the 2008 HHR. I've been chasing gremlins. I don't want to spend $200 for a full manual. If not maybe someone will recognize a link on all these problems? Not working- no remote start, no speedo, power steering error on, no out door temp light, engine light on, stiff shifting. I have checked and reseated all the connectors on the bottom of the fuse block. I'm thinking its a bad ground but I don't now where to look.
Thanks
Thanks
The no remote start and stiff shifting are probably a result of the check engine light code being thrown. Have you pulled the codes? List just the alphanumeric code, not the description which can be deceiving.
And to the forums!
And to the forums!
electrical
I'll have to borrow the code down loader again and repost. When I did it last time there were many errors and I was just overwhelmed. the problem started with a low battery I jumped the car in the winter and lost 3rd and 4th gear. After lots of trouble shooting I replaced the PCM and got 3rd and 4th back(must have hit it with the cable?), but now I'm left with other things not working properly. I would love to just have the dealer reprogram the ECM but I'm told they will only do that if it sold by them new.
Thanks
Thanks
Here is a link:
https://www.chevyhhr.net/forums/how-...cations-56504/
I just noticed the part about the PCM. What you did was short the module, the case is connected directly to ground. Who knows what other circuit is affected. Probably a ground wire got fried at least.
The PCM ground is on the top radiator support, driver side (G103). That point grounds a few other circuits.
nedwob
09-02-2018 12:38 AM
plovell66
08-04-2016 08:07 PM
rendon47
12-26-2013 08:40 PM
ZonedAgain
05-23-2011 06:28 PM
