09 HHR heater issue
Old 11-07-2019 | 08:04 PM
Euphorickate's Avatar
09 HHR heater issue
I have not utilized the search on any related topics yet.
I have an 09 HHR. It was a handmedown from somewhere on the coastline of TX. For some reason the heater does not work. I inquired to the previous driver and they said they believe the heater was unhooked or something?
How do I go about hooking it back up if that is such a thing.
Also, if IDK if there was a previous issue with the heater but what should I look for if it should not work?
Car is over 210,000 miles.
Old 11-07-2019 | 08:12 PM
I guess the first thing to do is figure out what "doesn't work" means. The fan doesn't blow, the fan blows room temp air etc.
Old 11-07-2019 | 08:30 PM
Well first I need to find out how to reconnect this, or to even see if the heater core is equipped. Do people usually just take the cores out? All I was told is it is disconnected.
Old 11-07-2019 | 08:47 PM
Is there something unreasonable about what I asked?
Old 11-07-2019 | 08:55 PM
G-Town's Avatar
Check to see if heater hoses are hooked up. This is under the hood kind of on the drivers side. Two hoses should connect to the heater core tubes poking thru the firewall. Post a picture if you are not certain.
Old 11-07-2019 | 08:57 PM
I will post pictures this weekend. Haven't got into it all yet. Thank you.
Old 11-07-2019 | 09:02 PM
Good luck.
Old 11-08-2019 | 09:07 PM
G-Town's Avatar
Heater Hose Location. Look between the brake cylinder reservoir and the back of the air cleaner. The second picture is where the two heater hoses connect to the thermostat housing. The third picture is where they connect at the firewall.
Old 11-09-2019 | 06:00 AM
After checking the hoses, check the radiator filler and the coolant level.
check the fuse boxes for loose fuses and relays .
Is the carpet wet on the passenger side foot well?
mikiec66
Maintenance and Upkeep
10-16-2019 11:13 PM
lisasvette
10-09-2015 01:43 AM
Smilesri
06-14-2014 05:51 PM
judy1bob
03-22-2013 09:53 AM
Arly08
12-28-2008 02:30 PM
Quick Reply: 09 HHR heater issue
