12v power outlets not working
Have a 2010 HHR LT and the 12v power outlets are not working, fuses have been checked and confirmed to be good, took a volt/ohm meter to the plug at the front power power @ dash and getting a fluctuating reading of 0-8v coming up and down repeating. I have never seen voltage readings doing this before.
Does anyone know what I can do next to diagnose or know what might be causing this problem????
Code reader works fine on the obd port, but i do not have anything plugged in constant on the obd port, but both power outlets have that fluctuation 0-8v and won't power anything
I've checked both fuses and circuits for the outlets, they both do exactly the same thing with fluctuation from 0-8v at the plug.
Ok, so there is nothing in the circuit like bcm or anything that could have an effect on power? Just battery, fuse box, then outlet?
I have never tapped into the circuit for anything else, this is a pert much pristine car, these plugs just stopped working one day and now I'm trying to figure out why?
They are always hot with no intervention from anything. You are the only owner? Nobody ever spliced a wire? No add ons? Original sound system? What have you been using them for? Anybody ever think they were cig lighter outlets? Fresh battery in your VOM? Anyone add fog lights etc.
