2006 Chevy HHR
2006 Chevy HHR
I have an issue I hope someone can help me with usually in the winter I'm driving and my car lights up like a Christmas tree than it says engine powering down and it does I pull over turn off the car for a min start it again and it's fine again till the next time been happening for years about 10 times a year the engine light stays on for a day or 2 than turns off I have taken it to so many garages and no one can do anything except take my money it's been hooked up to the computer and nothing shows can someone help me thank you
It never stays on long enough to get an apt at the garage that's what they all told me they said they can't tell unless the check engine light was on every garage says something different and I spend money to fix what they think it is an than it still does it just so tired of spending money for nothing this is kinda my last resort but thanx for the reply I really appreciate it
Could take a look at the fuse box under the passenger side waterfall, make sure the bolt holding it together is tight and the bolts holding the under hood fuse box halves together as well.
Check under the hood for loose/broken ground straps, there are a few of them. Basically wires bolted to the body/frame.
My 2006 2lt keep shutting down, it was the battry strap from the battery post under the hood to the fuse box had broken only made contact sometimes, I installed a copper strap on the battery post and a sheetmetal screw to the broken copper strap from the fuse box, it has been several years now and now I have a good battery connection no more problums and runs great.
And before attempting to clear any codes, you should try to have them read again.
If the scan tool is "failing to communicate" with your HHR, check the fuse for the cigarette lighter, if it's blown...the diagnostic port will not function.
