2006 engine dies at the first stop sign.
Old 11-14-2013 | 07:36 PM
yrrah's Avatar
Usually only happens when engine is not up to normal operating temp. The engine starts and runs fine after that!
Old 11-14-2013 | 07:57 PM
Welcome to the site.
Are you asking a question or for help?
Old 11-14-2013 | 08:15 PM
to the forum!
There are a half dozen possible causes that spring to mind, but I'm not going to get into them until you do one simple thing.
Take your HHR to your preferred auto parts store and have them "pull the codes", without knowing what OBD II trouble codes may or may not be stored in your HHR's memory.
When you get the codes post them up here, otherwise, we're shooting in the dark.
Old 11-15-2013 | 12:29 AM
Lucky's Avatar
I agree get the codes checked. If there are no codes I would start with a throttle body cleaning.
Old 11-15-2013 | 01:27 AM
And maybe clean the MAF sensor too.
Using MAF sensor cleaner only, it's cheap and easy to use, don't be tempted to use brake clean....that will contaminate the sensor causing more headaches.
Old 11-15-2013 | 07:55 AM
And check coolant level. Possible T-stat.
Old 11-15-2013 | 08:41 AM
I concur with all of the above, and Donbrew could have the winning stab in the dark, I just had the same issue last week, a new T-stat fixed the issue.
Jimmy~O
10-08-2013 02:39 PM
northrivergeek
03-14-2013 01:10 AM
duluth_hhr
01-19-2011 12:08 PM
gkshay
04-22-2009 05:31 PM
crzyrayman
04-10-2006 04:14 PM
Quick Reply: 2006 engine dies at the first stop sign.
