2006 engine swap with 2008 g6
Old 07-28-2018 | 05:10 AM
Jason Walker's Avatar
im thinking it might be the tune...im probably wrong though....lol...thanks yall
Old 07-28-2018 | 06:12 AM
The tune is in the computer system, not in the engine. If you are using the HHR's original ECM, PCM etc., then it will run off of that tune.
My guess is you've got a bad sensor that you swapped over between engines or a plug in not making a good connection. MAF or MAP sensor would be my 1st thought.
Try pulling the codes and see if it has triggered a stored code. You may find one that will point you to the problem.
phil121965
02-26-2020 10:30 PM
OshawaHHRss
11
08-04-2019 09:13 AM
06 HHR LOVER
11-13-2017 12:49 AM
DBHHRLT
2.4L Performance Tech
10-20-2014 05:41 AM
xzombie
09-01-2009 02:18 PM
Quick Reply: 2006 engine swap with 2008 g6
