2006 hhr basket case *need some help*
Old 06-21-2020 | 07:33 PM
Joshua Oleyar's Avatar
2006 chevy hhr.
codes: p0106, p0371, p0500, p0768, p0916, p0300, p0568
car will turn over and run momentarily but shuts back off?
any help is much appreciated
let me know what other info you may need to help diagnose.
thanks again
Old 06-21-2020 | 08:24 PM
Interesting, the p0371, p0500, p0768, p0568 have never been reported here.
Old 06-21-2020 | 08:32 PM
reasonably competent home mechanic lol... and im scratching my head. cleared codes, cleaned MAF, got it to sit idle.... but once you try to press the gas peddle it breaks up and shuts the engine off.
any wild guesses or where to
start would be much appreciated
Old 06-21-2020 | 09:24 PM
Never been reported because they don't exist. The only 2 that do exist is P0106 and P0300.
P0106 is for the MAP sensor not the MAF. Either a bad connection, a bad seal or a bad MAP sensor.
Old 06-21-2020 | 10:07 PM
?? just the codes the reader had.... MAP / MAF okay.... thanks....i think?
Old 06-22-2020 | 01:04 AM
geg's Avatar
geg
Originally Posted by donbrew
... Either a bad connection, a bad seal or a bad MAP sensor.
x2 + just for your peace of mind examine the entire air supply from the suction hose to the turtle
Old 06-22-2020 | 08:03 AM
https://www.obd-codes.com/p0106
https://www.obd-data.com/p0371.html
https://www.obd-codes.com/p0500
https://www.obd-codes.com/p0568
https://www.obd-codes.com/p0768
https://www.autocodes.com/p0916.html
These codes have a common issue , wiring! Inspect the connectors for bent pins , corrosion, broken wires, inspect the ground wires, are they clean and tight? Inspect the TCM connector and howsabout the fuse box under the hood, these codes rarely show up, but they are all connected to the computers, via wires!
Old 06-22-2020 | 12:31 PM
Cat Man HHR's Avatar
Erase all codes.
There are too many.
See what ones are predominant and go from there.
Old 06-22-2020 | 02:30 PM
This sticky thread from Chevymgr agrees with donbrew. Those are apparently not HHR codes.
https://www.chevyhhr.net/forums/www....ad.php?t=14259
Old 06-22-2020 | 04:04 PM
They might not be specific to the HHR, might be the code reader. Could be all those loose connections .
Try CatMan’s theory, disconnect the negative cable at the battery for a full 30 minutes, reconnect it and keep an eye on the CEL
Quick Reply: 2006 hhr basket case *need some help*
