2006 hhr basket case *need some help*
Old 06-26-2020 | 07:38 PM
  #31
Post #25. "checked plugs cylinder 1 and 4 have oil on them."
Oil on the spark plugs is a major issue. Trying to fix all that other stuff is useless if you have major engine problems.
Old 06-26-2020 | 07:45 PM
  #32
Oil on the plugs where external from the valve cover leaking oil, oil on the electrodes internally in the combustion chamber?
Old 06-26-2020 | 09:26 PM
  #33
Joshua Oleyar's Avatar
not 100% sure.... when i first pulled plugs 1 and 4 had oil dripping off when i pulled them out. so not sure if it was inside or out of the combustion chamber. but ran it again for awhile and the electrodes weren't wet when i pulled the plugs again. so maybe valve cover???? let me keep digging. thanks guys
Old 06-27-2020 | 11:47 AM
  #34
The working end of the plugs is inside the combustion chamber.
Old 06-27-2020 | 12:06 PM
  #35
If it’s dripping it’s from the valve cover gasket leaking.
danthemancamaro
06-04-2015 12:18 PM
rendon47
12-26-2013 07:40 PM
coolace
03-11-2013 07:37 PM
dvalin
04-02-2008 09:25 PM
Quick Reply: 2006 hhr basket case *need some help*
