2006 HHR Blower Motor Removal?
Old 11-07-2009 | 04:03 PM
kaylar30's Avatar
let me know if that works .. because mine did the exact same thing .. and they are saying it is going to be anywhere from $450 - $700 to fix it ... and well I live in Canada .. going to need a fan soon enough!
Old 11-09-2009 | 06:13 PM
skyeglen's Avatar
I had to replace the resistor back in Feb. of this year due to water damage. Several weeks later the blower fan motor started skreeching whenever it was turned on. I pulled the blower motor out, uusing the diagram found on here from ChevyMgr, put a few drops of electric motor oil on the shaft under the fan cage and ran the motor for a few minutes. The motor quieted right down so I put a few more drops on the shaft and put it back together and 9 months later the fan is still quiet on all speeds.
Old 05-27-2010 | 06:48 AM
mcgaugh's Avatar
Is the blower motor resistor located under the hood?
Old 05-27-2010 | 07:22 AM
oneton's Avatar
NO under the dash near blower
Old 05-27-2010 | 12:53 PM
an08HHR's Avatar
see post 19 for pic in this thread https://www.chevyhhr.net/forums/show...t=14263&page=2
Old 05-27-2011 | 09:58 PM
metal5818's Avatar
I guess I must be slow , couldn't understand by all the posts how to actually remove the blower motor . A heads up for the next person . You actually have to cut all the way around the inner and outer cases . When you look up you can see three pairs of holes aligned for screws that should have been used at time of assembly , a hole on inner ring and the other outside the outer ring . I made 3 bridge brackets and used small screws to install the housing in place after "rebuilding" the motor . Hope this helps the next person , sure would have saved me some time .
Old 08-07-2011 | 03:16 PM
amagar's Avatar
I got the same problem on my 2006 HHR Damn water leaking out the passenger side then the blower motor going out. Sucks Damn GM they should put a recall on those problems with the HHR. So many peoplehaving the same problems !
Has anybody hav the key not turn to the lock position wen u put it in park on the HHR? Wats The cheapest fix ?
kuzzins
01-02-2016 09:09 AM
Element
09-20-2013 02:45 PM
kniffen
03-06-2013 08:13 PM
Quick Reply: 2006 HHR Blower Motor Removal?
