2006 hhr EPS problems
Old 08-17-2019 | 11:56 AM
acookesp's Avatar
i have a 2006 chevy hhr Lt. i have taken it to gm and they said they replaced the electric power steering. i drove it for a week and had to take it back and they say its not an eps issue. i have drove it for a few days and it stopped on me but started right back up....CAN ANYONE HELP ME OR HAVE ANY IDEA WHATS THE PROBLEM SO I CAN FIX IT MYSELF...THANKS
Old 08-17-2019 | 01:06 PM
Can you give a more detailed description of the issues before and after the replacement? Mileage would also help along with when the power steering motor was actually replaced.
Old 08-17-2019 | 01:07 PM
From your post I have no idea what the problem is with your car...
Need some more details... Like "it stopped"... What stopped? What does it "stopping" have to do with the eps?
We can't help if we don't know what to help with.
Old 08-17-2019 | 02:52 PM
It stopped on you, was the ignition recall done on your HHR
Old 08-17-2019 | 09:48 PM
acookesp's Avatar
the power steering would go in and out on me, when i use cruise control it doesnt work going downhill, the cruise control doesnt work sometime, the steering wheel is hard to turn...these are the problems that were happening before AND STILL after their so-called replacement. i called gm and they said their was a warranty for the eps and that sounded like the problem.the mileage was around 137k when i took it in to get replaced. difference NOW IS...the wheel never locked up on me, and the car never shut off/ stopped on me- and this has happened AFTER I TOOK IT IN TO THEM...i have taken it in twice and it seems as if it gets worse after their 'repairs'.
Old 08-17-2019 | 10:37 PM
.... and the ignition switch recall?
Here is a link to check on recalls https://www.chevyhhr.net/forums/gm-r...-status-50716/
Old 08-17-2019 | 10:45 PM
Any competent dealer wouldn't have let the car leave leave the shop without doing the ignition switch recall... Key word "competent".
This shop doesn't seem like they quite fit that description though.
R CA HHR
03-04-2020 09:38 AM
dwolford59
01-27-2015 06:09 AM
jimi
05-06-2014 02:15 PM
GoJo65
09-16-2013 05:36 PM
Maccabeus
10-18-2009 04:14 PM
Quick Reply: 2006 hhr EPS problems
