2006 Oil Leak
Old 02-20-2019, 01:43 PM
billmac77's Avatar
2006 Oil Leak
Well, it turns out the oil leak is the gasket on the upper oil pan. Mechanic estimates about $1000 to fix it. Probably not worth it unless there's some kind of little known wizardry that can be done to seal it or slow it down.
billmac77 is offline
Old 02-20-2019, 01:51 PM
billmac77's Avatar
Do any of the leak sealant additives work? Even a little? This car has been on borrowed time, so even if I got 6 more months out of it, it would be worth it to nurse it along.
Old 02-20-2019, 01:57 PM
Doc brown's Avatar
How bad is the leak? I have a leak in the gasket just above the oil sending unit. Just a drop a day and only in cold weather. A few years ago I switched to full synthetic oil. Over time the leak stopped. I think it simply got gunked up and plugged itself. I'm not a fan of oil additives in modern engines.
Doc brown is offline
Old 02-20-2019, 02:14 PM
billmac77 - can you redefine what you mean when you say "upper oil pan"? There is only one oil pan. Do you mean it's leaking from the top of the lower crankcase?
whopper is offline
Old 02-20-2019, 02:16 PM
hurst2001's Avatar
you can try AT205 look it up on on YouTube Scotty Kilmer has a thing about which might help you out ..
hurst2001 is offline
Old 02-20-2019, 02:19 PM
billmac77's Avatar
I'm only going by what the mechanic said to my wife. He said it required removing the timing mechanism, if that helps.
Old 02-20-2019, 02:39 PM
Cat Man HHR's Avatar
Your going to have ask him (mechanic). Does he mean the cover for the chains on the front of the engine ?
It's called the front cover.
Cat Man HHR is offline
Old 02-20-2019, 02:53 PM
ChevyMgr's Avatar
Resealing an oil pan should only be $300-$500 depending on labor rates in your area. No gasket needed, just sealer.
ChevyMgr is offline
Old 02-20-2019, 03:00 PM
H'mmm; 2006: perhaps the oil cooler O-rings?
donbrew is offline
Sometimes a good picture to clarify the source of the leak, it could but from sloppy oil filter change , that would dribble in the vicinity of the oil pressure switch,or it could be the oil pressure switch itself leaking , a common problem
https://www.chevyhhr.net/forums/how-...ng-unit-57962/
Oldblue is offline
Quick Reply: 2006 Oil Leak
