2007 hhr won't start
Old 03-18-2013 | 07:03 PM
Remember those compression numbers? It doesn't sound good if you've got blowby. You need to recheck the compression after you fix the radiator and run it some to burn off any excess oil.
Hope you get lucky.
Old 03-18-2013 | 10:04 PM
jtuchol's Avatar
I just ordered the rad. we will see, I don't feel good about this...
Old 03-25-2013 | 09:37 PM
jtuchol's Avatar
got new radiator in, ran car, still has a lot of blow by, going to try any pull spark plugs and fill cylinders with sea foam and leave sit work back and forth and try and get rings to work loose, then do another compersion check. if engine is shot it's worth a try before replacing engine.
Barneyson2
09-30-2014 06:37 AM
Farmers Daughter
03-11-2013 11:02 AM
HillsdaleHHR
02-21-2009 02:26 PM
pea420
2.4L Performance Tech
11
10-16-2007 09:36 PM
GDZHHR
04-06-2007 01:47 PM
Quick Reply: 2007 hhr won't start
