2008 hhr ac compressor
Old 06-30-2019 | 04:08 PM
Of course, we should ask if all of the controls are set properly. Temp knob all the way blue, fan on, blowing in face etc.
Old 06-30-2019 | 04:25 PM
drscott's Avatar
As I said I'm done for the day, but one thing I did ,as in in construction is hose down my condenser and radiator and got alot if dirt out, so now waiting for my fan to kick on
Old 06-30-2019 | 04:26 PM
Abra-Cadabra
Old 06-30-2019 | 04:35 PM
drscott's Avatar
I wish!!!! Still no ac but electric fan works! No magic there!!
Old 06-30-2019 | 04:57 PM
If you're curious where the pressure switch is, it's on the hose block at the compressor. (round silver thing inside the circle)
Old 06-30-2019 | 05:37 PM
  #26
He said that was replaced.
If somebody put a fuse in place of the diode I don't know what would happen.
  #27
drscott's Avatar
Thanks, it is connected but cant find the diode for the compressor, but then again I'm indulging in adult beverages for tonight, if you can find me a picture of where that is it sure be helpful sir.
Old 06-30-2019 | 05:45 PM
  #28
There is a drawing in the owner manual, also a diagram on the inside of the fuse block cover, underhood.
Old 06-30-2019 | 06:20 PM
  #29
drscott's Avatar
The thing I pulled out of #9 I replaced it with the headlight one, it has the same numbers but when I did that it was extremely hot, so I put the original back in and that one was hit as well.
Old 06-30-2019 | 07:16 PM
  #30
Well now something is probably burned up. Diodes are NOT the same as Fuses. A diode blocks the flow of electrons in one direction a fuse lets them go either way.
Quick Reply: 2008 hhr ac compressor
