2008 Hhr ss leakin rain water!! Help!!!
Old 11-02-2013, 06:59 PM
C-DUB's Avatar
Blown all sunroof drain lines out, took all leaves n stuff out from around wipers. Even had a buddy spray hose on car for 30 min didn't see any water get in, but when it rains the front pass floor mat is soaked, so is carpet and there's a puddle under the carpet!!
C-DUB is offline
Old 11-02-2013, 07:48 PM
Radco's Avatar
Seems to be a commonissue
Try the search box.
I found these. hope someone will give you better advice then me
https://www.chevyhhr.net/forums/problems-service-repairs-42/water-leak-front-passenger-floor-29690/
https://www.chevyhhr.net/forums/show...091#post506091
https://www.chevyhhr.net/forums/problems-service-repairs-42/2nd-water-leak-solved-after-butyl-patch-42633/
Radco is offline
Old 11-06-2013, 06:24 AM
JJBoxer1's Avatar
That is a patch under your windshield wipers, remove wipers, then remove the cover, under that you will see a patch covering a hold there, remove that patch and replace it, make sure you buy a sealer to attach the patch back in place to cover that hold, you will have no more cabin water leaks.
JJBoxer1 is offline
Old 11-06-2013, 06:31 AM
JJBoxer1's Avatar
I took off the cowl piece under the wiper arms and saw the rubber piece that covers a big whole,
leaning in toward the passenger compartment, looked just like a funnel that was directing water that way.
Must have knocked it loose when putting in the new windshield.
That tar looking crap the factory put on it was dirty, so it couldn't be used again.
Pulled all that stuff off, cleaned it up, put a nice bead of black silicone on the rubber let it set a few minutes, put it back on the car pressed it down a little and dried over night in the garage.
Water leak fixed. ... Thought about taking pix after I was done..doah. This could have helped someone fix their problem. Maybe it still will.
Also, from it being wet, it blew my blower resistor.
Had to buy another one today:
cost = $44 from stealership
no more wet floor & blower works on all speeds = priceless
JJBoxer1 is offline
Old 11-06-2013, 06:34 AM
JJBoxer1's Avatar
Go here and see pic on how to repair the leak inside the car https://www.chevyhhr.net/forums/how-tutorial-library-21/fixed-my-water-leak-last-night-14263/
JJBoxer1 is offline
Old 11-06-2013, 08:01 AM
JJBoxer. The butyl patch issue that you're refering to was only for the early model HHR's. C-Dub has a 2008, so that butyl patch is not going to be his problem.
firemangeorge is offline
Old 11-06-2013, 11:37 AM
C-DUB's Avatar
Correct, not butyl patch as they changed the design in late 07'
Cabin filter is bone dry, but floors get soaked. I noticed a couple drops INSIDE the glove box, so I am ruling out the wire harness for the doors as they are lower then the glove box.
I am going to check the doors themselves, and the mirrors to see if the doors are leaking water high up rather then the drain holes, but I highly doubt it is either of those.
I drilled out the sunroof drains, and checked them again the other night, all flow water good and strong so its not the sunroof.
Never leaked a drop in 1.5 yrs of me driving it. Left it at my parents for 2 weeks in the direct sun, started leaking after. I thought maybe it was the pine needles clogging draings but I believe I cleaned all of them out. Could the direct sun have done something to the front window? Has anyone heard of the front window causing issues?
C-DUB is offline
Old 11-06-2013, 12:08 PM
your Mom and Dad take the HHR for a joy ride and play with the sunroof?? LOL this is one of those keep looking issues, you will find the leak but hurry up winter is coming! suggestion pull the windshield side garnish moldings and check for water there it could be the windshield seal has failed
Oldblue is offline
Old 11-06-2013, 02:58 PM
C-DUB's Avatar
do the moldings on either side of the window just pop off and on?
C-DUB is offline
Old 11-06-2013, 07:07 PM
have to open the caps and remove the screw, do one side at a time
Oldblue is offline
Quick Reply: 2008 Hhr ss leakin rain water!! Help!!!
