2008 Hhr ss leakin rain water!! Help!!!
I'm having a similar problem with my '08 SS, too. I think it is coming in through the RF door seal maybe, but it doesn't happen all the time when it rains, so it's been hard to isolate. Interested in hearing if there's a resolution to this...
Have you looked at the door wiring harness seals?
I can do that. I've been busy with work, and kind of forgot about this until I saw the topic. I got some WeatherTech mats now, so all it does is puddle on there, but I still should look into this more. The soggy carpet was much worse, believe me...
My bad
Ok guys didn't know that they had change that, Ok check this out! I purchase a 2007 Pontiac G6, we had a storm here I was at work, when I went out for break I notice that the passenger side floor was wet in this car like it had been in my HHr so I check to see if the drain tubes were pluged, open the moonroof had water in a bottle and pored it near the wind net, the water came out by the panel on the side were you feet are, so I removed the sun visor then the rubber around the front of the moonroof, pulled the head liner down some, and saw the tube that connect to the drain hole was disconnected, so I reach the tube reconnected it, took eletrical tape and rap around it, then I poured water near the drain hole again, the water came out of the spot it was suppose to.
pindars
Drivetrain (Excluding Engine)
08-05-2014 06:28 AM
roofer1976
09-18-2009 09:38 AM
