2008 won't crank
2008 won't crank
2008 LT, 250,000 miles. Makes a sound like a sewing machine when key is turned. Does not try to crank. The sewing machine sound will continue as long as key is turned. Battery is a couple years old but seems fine, all lights, dash, horn all are powered up. Ignition switch replaced a month ago, but in the last few days before this problem started, it has stiffened a little?? No check engine light. I am not knowledgeable about vehicles at all, want to be clear about that. Just posting to see if anyone may have experienced something similar and could help point me in the right direction.
If it is not cranking the chain ain't making noise.
Relays make noise, Solenoids make noise.
Was the ignition switch replaced under the recall?
Check the VOLTAGE of the battery. It should be above 12.75 V.
