2008 won't crank
Old 10-19-2019 | 10:04 AM
Carl B's Avatar
2008 won't crank
2008 LT, 250,000 miles. Makes a sound like a sewing machine when key is turned. Does not try to crank. The sewing machine sound will continue as long as key is turned. Battery is a couple years old but seems fine, all lights, dash, horn all are powered up. Ignition switch replaced a month ago, but in the last few days before this problem started, it has stiffened a little?? No check engine light. I am not knowledgeable about vehicles at all, want to be clear about that. Just posting to see if anyone may have experienced something similar and could help point me in the right direction.
Old 10-19-2019 | 10:44 AM
Welcome to the site, I’m thinking timing chain and or guide.either should trigger a code.
Old 10-19-2019 | 11:27 AM
Carl B's Avatar
Thanks for your response. I'll get the codes checked out.
Old 10-19-2019 | 12:53 PM
If it is not cranking the chain ain't making noise.
Relays make noise, Solenoids make noise.
Was the ignition switch replaced under the recall?
Check the VOLTAGE of the battery. It should be above 12.75 V.
Old 10-19-2019 | 07:55 PM
Maybe something in the HVAC is making the noise.
Old 10-19-2019 | 10:11 PM
fastsuv's Avatar
Maybe the starter is not engaging the flywheel and that is the "sewing machine sound", a freewheeling starter motor?
Steve
Old 10-20-2019 | 06:58 PM
Carl B's Avatar
Thanks for the replies. Yes, the ignition switch was replaced under the recall just 3 weeks ago.
Old 10-20-2019 | 07:01 PM
I’m wrong about the timing chain, starter is much more the possibility .
Old 10-21-2019 | 11:07 AM
Carl B's Avatar
OK Thanks. I'll let all know what I find out.
Old 10-21-2019 | 07:39 PM
Pull the starter (a 15 minute job) and check the Bendix gear on the end of the starter shaft as well as the ring gear for abnormal wear.
Quick Reply: 2008 won't crank
