2008hhrss
Old 04-15-2008 | 07:03 PM
dominick's Avatar
2008hhrss
Anyone having problems with engine compartment noises entering into.clicking ticking sounds like valve tappents. Gm claims along with service that this is normal due to high pressure fuel pump and fuel injectors. This annoying and not acceptable to me. Any one else?
Old 04-15-2008 | 07:38 PM
an08HHR's Avatar
Normal as gm said. There is a thread on this is the SS section I believe
found this thread https://www.chevyhhr.net/forums/hhr-ss-45/info-about-injector-fuel-system-tick-12726/
here is another https://www.chevyhhr.net/forums/show...=ticking+noise
Old 04-15-2008 | 09:38 PM
hhrcrafty's Avatar
It's a direct-injection engine, just like a diesel, so you're going to have injector clatter, and there is no insulation under the hood on the SS to reduce the noise. This is something that the Solstice/Sky owners have been dealing with for a while too. You might look into putting some Dynamat under the hood to see if that helps, or even the hood blanket that comes on the non-SS models for noise reduction.
Old 04-15-2008 | 11:15 PM
ivtech's Avatar
I have the clicking at start up last for less than 90 seconds. Not a problem for me.
Old 04-15-2008 | 11:18 PM
chevyguy's Avatar
I guess I need to get my hearing checked, I don't hear anything other than the exhaust and what I would consider normal engine noise.
