2009 chevy hhr
Old 11-21-2012 | 01:23 PM
sexyclw's Avatar
Question 2009 chevy hhr
I have a 2009 Chevy hhr. It is running hot( very bad) and the heater has. Stopped working. What do you think is the problem?
Old 11-21-2012 | 02:01 PM
solman98's Avatar
My first guess would be stuck thermostat, closed at that. But since your heat isn't working, does that mean no heat or fan not blowing?
Old 11-21-2012 | 02:35 PM
Did you consider checking the coolant level?
Old 11-21-2012 | 03:56 PM
badassbowtie's Avatar
those two symptoms sounds like a waterpump...but a thermostat stuck closed would mimic a broken waterpump
Old 11-21-2012 | 06:23 PM
IMPALADAKID's Avatar
how many miles on it? I think thermostat and water pump are covered under the 5/100 warranty. But check the coolant level first.
Coyolmitl
06-13-2015 05:54 AM
TyroneMD
02-03-2010 11:11 AM
Quick Reply: 2009 chevy hhr
