2009 cruise control problem
Old 07-12-2013 | 05:46 PM
dkitch's Avatar
the third brakr lite is out is it on a fuse can't believe all 5 bulbs are out thanks
Old 07-12-2013 | 07:45 PM
It happens! Check the bulbs first, could use a VOM to check for voltage.
Old 07-12-2013 | 08:23 PM
Yes, they are on a fuse - check your Owners Manual for location and size of the fuse if the bulbs check out.
Old 06-27-2014 | 10:27 PM
wp925's Avatar
Found this on the web because I have the same problem. Replace high brake lights since they were all burned out. Cruise control still does not engage or display on dash.
Old 06-27-2014 | 10:33 PM
Have you tried our search tool? There are several reason the CC wouldn't work.
Did it ever work? If it did, what is different now?
Old 06-27-2014 | 10:53 PM
Lucky's Avatar
I would check the codes. Some codes will disable the cruse control if not cleared.
myers1wa
02-06-2018 03:59 PM
dbldown
02-19-2014 08:08 AM
hhrumadbruh
10-26-2012 07:53 PM
andoll83
2.4L Performance Tech
01-04-2008 11:23 PM
calgaryhhr
06-04-2007 07:04 PM
Quick Reply: 2009 cruise control problem
