2009 winshield wiper linkage
Good morning, I think ill go to a few junk yards today...my driver side wiper quit on me, and I can see its the linkage. What other years are compatible with the 2009? I have never had this problem before.
As far as I know, the linkage is identical from '06 to '11.
Give this thread a read too, some helpful hints...
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-fix-wiper-transmission-32975/
yeah, check out that link - I fixed mine years ago using that posting by drilling it out slightly and putting in a bolt, some washers, and a couple of nuts on the bolt, and a good bit of grease, and it is still holding up.
Mine did the same thing about 6 months ago. As the above post said, Just drill through the elbow joint and put a bolt through the hole with a washer on it. Dont tighten it down all the way though. Leave a little play or the arm will not articulate. Mine is better than new and no problems since.
Dorman full transmission, with the years that fit
https://www.dormanproducts.com/p-85113-602-212.aspx
wrecking yard will work, but for how long?
I replaced Oldblue’s wiper transmission several years ago , and kept the old one to do the drill and tap repair, when the BlackSwan needs to be repaired
per our parts thread page #3
Wiper mechanism repair - - suggested by donbrew/jeanvaugeois
- DORMAN P/N: 49447 (wiper linkage bushing assortment)
