2010 Chevrolet HHR Panel LS Rear Speaker Wire Colors
I'm going to install a Line Converter (High to Low Level) on a Stock Base Radio. Could someone let me know which are the Rear Speaker wire Color Codes. I tried to use the info at:
http://www.modifiedlife.com/2010-che...-wiring-chart/
However this site does not indicate the trim level that their system calls out. When i tried to find the wires as noted I found no Brown wire.
I would like to pick up the wires under the Passenger Side Kick Panel rather than behind the Radio. I will locate me small Amp under the Passenger seat.
Can anyone assist to facilitate this plan?
Thanks!
Thanks!
BunglerHHr
10-12-2012 01:00 AM
