2010 HHR 2.2 Starter wire questions
Ok so I did a full engine swap and I think I have my starter wires messed up.
Starter has the 2 bolts holding it to the engine and two posts for wires.
Top post gets the cable from the battery and the cable to the alternator?
Bottom post gets what?
Thanks
Stephen
Thanks
Stephen
I did a full engine swap and I had to take the starter off my old engine and move it over. All that got removed before I pulled the engine out so once it was all back in the starter isnt trying to turn guess forgetting to ground it will do that.
Tonight going to try again
Ol my bad I was miss understanding. I know what wire you guys are talking about that is still on there i didn't take that one off. So no other wires go on that post? There is a loose ground wire that is part of the wiring harness looks like it is about 12" long I did forget to hook up.
That unused one might be the one from the top of the trans to the rad support.
https://www.chevyhhr.net/forums/how-...cations-56504/
