2010 HHR idling problems
i have a 2010 HHR with 92k miles. it got in an accident a couple years back, it hasn’t been touched up until recently. i went to try and start it and the idle jumps up to 3000 rpm’s right when you start it and usually dies after a couple seconds. i know the throttle bodies are known for having issues, so i read the codes with a code reader and sure enough it had throttle body and maf codes. however i replaced those along with new spark plugs and brand new gas since it was sitting for a while. all the codes went off and it still does it. i know you can do the throttle body relearn but i can’t keep it running long enough to even do it. if anyone has any information that would help me i’d really appreciate it! thanks!
If the OP hasn’t cleared the codes, then they should show as stored or historic.
Plus. If it’s running (or not running) as bad as he says, then it should throw a code or 2 and light up the CEL before too long.
Without any codes we could blindly guess all day long.
Sorry. Guess you don’t understand how CEL’s and the codes work. Even though the light went off, you can still have codes stored in the memory …..as long as you didn’t erase them with your reader or disconnected the car battery(reboots and clears the OBD system.
My point was to pull the codes again. Even with the light off there could be stored codes.
If the car has been sitting unused for a long time, the battery is discharged or just no good anymore. Take it to the auto parts store and get a free battery load test.
That it is strong enough to start the vehicle is not a good indicator of battery health.
