2010 HHR idling problems
Old 12-09-2022 | 06:53 PM
You replaced spark plugs? What brand and part number?
AC Delco 41-103 iridium I hope!
Have you inspected the connector wiring at the throttle body?
Old 12-11-2022 | 09:25 AM
masonlis's Avatar
well i can’t even relearn the throttle body because i can’t even keep it running long enough. it dies immediately. but i pulled the plugs yesterday to check and make sure i had good spark and the brand new plugs i put in were completely black. if that helps anyone lead me in the right direction.
Old 12-11-2022 | 10:25 AM
Which plugs are in there?
Old 12-11-2022 | 11:18 AM
Black plugs makes me think the butterfly is stuck closed.
Old 12-11-2022 | 12:54 PM
Yes, running very rich.
Old 12-11-2022 | 01:54 PM
masonlis's Avatar
do you think that maybe the throttle body i got is fualty ? i did get it out of a junkyard. but even beofre i replaced the symptoms were the exact same and didn’t even change once i put the other throttle body on.
Old 12-11-2022 | 02:42 PM
greg8453's Avatar
You need to put a scan tool on it and see what it's doing.
Need to see what the load devises are doing. MAF is first. See what the PCM is commanding the injectors. Could be they are being commanded for idle which would mean your injectors are bad.
Old 12-11-2022 | 04:02 PM
Switch back to the other throttle body, see if there’s any changes. And please , answer me about the spark plugs!
Fedves86
09-27-2021 04:37 AM
Fire_Wessle
2.2L Performance Tech
14
05-07-2021 06:34 AM
zach7402
07-28-2020 10:47 PM
michael sovern
05-29-2019 11:37 PM
mls72priss
10-29-2016 05:45 PM
Quick Reply: 2010 HHR idling problems
