2010 HHR passenger headlight intermittent
Old 04-17-2014 | 04:40 PM
Dealer would be happy to CHARGE you to fix it. If you are outside 3/36,000 you gotta pay somebody.
Old 12-16-2014 | 06:15 PM
Bull dog's Avatar
Same problem with 2007 HHR
Hi there,
I own a 2007 Chev HHR and I have the identical problem with my low beam on the passenger side working intermittently. Mine started when the cold weather began here in Alberta. I will check all the things that the other respondents suggested to see if I end up in the same boat of frustration as yourself. In the mean time if anyone has found out the cause of this problem please contact me.
Thanks
Old 12-16-2014 | 10:47 PM
Lucky's Avatar
Welcome to the site
First question. Did you change the bulb?
Old 12-17-2014 | 07:16 AM
Welcome to the site! Bull dog, also check ground wire connections are clean and tight!
joe gilletly
12-13-2013 03:27 PM
saturnsw2
09-26-2011 06:04 PM
ChevyMgr
08-22-2009 11:17 AM
Quick Reply: 2010 HHR passenger headlight intermittent
