2010 LT rear hatch release malfunction
The rear hatch release on my 2010 LT intermittently won't work. All the other locks work. I press the release pad on the hatch and nothing happens no sound or anything. I turn the car off and lock it. When I check it after 10 minutes it works fine. It happens in warm or cold temps. It seems to happen after driving. Could there be a connection problem or a relay problem?
Just a guess you may have a bad touch pad.
Here is a thread to give a read it has a tsb that explains some good diagnostics.
The tsb is for 2006 models but the diagnostic should still be the same.
https://www.chevyhhr.net/forums/prob...ur-dealer-524/
