2011 Chevy HHR with car/lock symbol
Old 06-19-2018 | 09:14 PM
SullyinCT's Avatar
I probably won’t authorize any work. I can take it to autozone and have them do a load test on the battery. I can’t afford any big fix. Will try to do it on my own I guess.
Old 06-19-2018 | 09:21 PM
More than likely this will fix it:
Old 06-20-2018 | 05:12 AM
SullyinCT's Avatar
Thank you for sharing!
Old 06-20-2018 | 06:39 AM
SullyinCT's Avatar
So the dealership is saying that the diagnostics are still showing old history codes.::communication codes dealing with the ECM and BCM. Mechanic checked those wires and connections and it appears to be fine. He would have checked the fuse box and connections this morning but I don’t have time for that. I’ll do it on my own.
Old 06-27-2018 | 01:39 PM
Howard Plasket's Avatar
Question
I have the 2008 HHR LS, have the 'brains' changed at all throughout the model years. Recently I have been having the same issue where the dash just goes funky. It started as a coolant temp gauge continually going flat on me. Took it to Firestone, and they checked it out. They said they didn't think it was the gauge but an electrical problem so they didn't charge me a dime. Was just going to change the thermostat for the 3rd time in as many years til the dash problem hit. Any suggestions?
Old 06-27-2018 | 02:35 PM
Please watch the video in post #12. He shows how to get to the connectors under the fuse box, Usually just re connecting does the fix, some dielectric grease helps.
Old 06-27-2018 | 03:05 PM
Hi Howard, to the forums!!
What donbrew said above, also, have your battery load tested and post the voltage/amperage results up here.
The only thermostat we can recommend is (2006-2011 All Models)
ACDelco 131-158 GM P/N 12622410
electronik2408
08-12-2017 07:43 AM
SpeedDemon
2.2L Performance Tech
7
08-06-2014 01:12 PM
dsmisfits
01-06-2011 08:39 PM
Quick Reply: 2011 Chevy HHR with car/lock symbol
