5 speed shifter problem
Lower gears 2nd, 4th, & reverse arent responding. How do I check my cable?
Code numbers? There are two cables. One upper on top that i can reach easily and one under that one that connects to a horse shoe looking thing.
http://www.justanswer.com/chevy/56wz7-chevrolet-hhr-lt-hhr-manual-transmission-shifting.html
But mine is 2nd, 4th, & reverse not working.
Automatic transmission cable
Chevrolet HHR SHIFT CONTROL/AUTOMATIC TRANSMISSION
Is the transmission end engaged or broken?
2nd, 4th, and reverse-when you try to put it in those gears it wont hold just shifter stick just goes back to neutral position. I can mess with top shifter cable to put it in 2nd and 4th but cant move cable enough to get it into reverse gear.
