5 speed shifter problem
Old 12-19-2016 | 11:10 AM
pelicantroopleader's Avatar
Pelican. Is your's a automatic trans. or a 5 speed stick shift ? Reason for asking is because the 5 speed has 2 cables, the auto only has 1.
5 speed 2 cables
Old 12-19-2016 | 11:11 AM
Originally Posted by Oldblue
Automatic transmission cable
Chevrolet HHR SHIFT CONTROL/AUTOMATIC TRANSMISSION
Is the transmission end engaged or broken?
5 speed manual transmission-2 cables
Old 12-19-2016 | 11:12 AM
Then if a manual perhaps the bushings are shot?
Chevrolet HHR Transmission Shift Cable Bushing Repair Kit
http://www.tonkinonlineparts.com/sho...=0&modelYear=0
Old 12-19-2016 | 11:17 AM
I can drive in 1st, 3rd, and 5th but no go for 2nd, 4th, and reverse.
Old 12-19-2016 | 11:19 AM
Ah ha. The reason for the confusion is because you jumped into another persons thread that was discussing an automatic trans. cable problem.
Next time you should start your own thread with pertinent info such as yours is a standard shift.
Old 12-19-2016 | 11:22 AM
Probably a broken cable. One cable works one side of the shift gate pattern. The other cable, the other side.
Old 12-19-2016 | 11:23 AM
If the check engine light is on as you say, what is the code downloaded? (the actual code, not a verbal description)
Old 12-19-2016 | 11:26 AM
I'll have to take it to autozone to have them tell me the codes.
Old 12-19-2016 | 11:28 AM
Any ideas how I can replace the cables? I am going to replace both of them but dont know what parts I will need. Not much information on hhr part numbers etc.
Old 12-19-2016 | 11:48 AM
The SS turbocharged got a different 5-speed than the non-SS, you haven't specified which trim level you have, so here's both:
SS - CABLE. Transmission Control Cable. SHIFT CONTROLS/MANUAL TRANSMISSION for Chevrolet HHR (2008 - 2010). #15939191
non-SS - CABLE. Transmission Control Cable. MANUAL TRANSMISSION SHIFT CONTROL for Chevrolet HHR (2004 - 2011). #15277760
You should look at it first, at both ends, to make sure that something just hasn't come loose.
Quick Reply: 5 speed shifter problem
