ABS Code "C0292-1A"
Old 08-06-2019 | 08:20 PM
Crank_Grinder's Avatar
Question ABS Code "C0292-1A"
I have a 2011 Chevrolet HHR, with 137,703 miles, a 2.2L and automatic transmission. A few weeks ago on my way home from work my ABS began to randomly activate as I drove down the highway. The ABS was activating when I lightly applied the brakes, and I was on bone dry pavement. I pulled over and looked over my car, thinking I had a wheel bearing or caliper hanging up. After I looked my car over, all of my wheel centers were cool to the touch, and there were no signs of a stuck caliper. I deactivated the ABS/Traction Control via the button above the radio and drove home, and the ABS continued to engage after I had "disabled" the ABS via the button above the radio. By the time I got home (15 miles) there was a message flashing in the cluster "Service ESC" and "ESC Off." I drove the car a few weeks hoping that the problem might go away with time. It has been nearly a month and I got around to stopping at an AutoZone and having the code read this last weekend. The code I was given was "C0292-1A" - "Multi Axis Acceleration Sensor Module Circuit - Performance Bias Out Of Range." I spent the weekend trying to find something on this sensor, and I am having a hard time even coming up with the location of this sensor. I would like to fix this problem so my ABS is operational by the time snow is falling...
Any advice or help is greatly appreciated!
Old 08-06-2019 | 09:10 PM
That would be the yaw sensor. It lives under the passenger seat left front.
If you change it you will need to calibrate the steering angle sensor with a Tech2 or similar.
Old 08-07-2019 | 04:53 AM
FYI
That button will not deactivate the ABS system. It is only for turning off the ESC and TCS. All the details are covered in your owners manual.
Retrokid
07-11-2019 06:13 PM
Sydnika
2.2L Performance Tech
15
12-29-2016 12:19 PM
questionMARK
10-21-2016 02:27 PM
rjdelapp
07-26-2012 10:56 AM
helhedded
03-22-2012 06:55 AM
Quick Reply: ABS Code "C0292-1A"
