ABS and Tc light on
Old 10-28-2017 | 09:30 PM
handspiker's Avatar
ABS and Tc light on
i checked the wires from each rear wheel.the wires seem to be ok.i changed the passenger rear wheel bearing and sensor.but the abs light and tc light still come on for the passenger rear wheel.dont know why.
Old 10-28-2017 | 09:58 PM
Do you mean that you are getting a c0050 00, c0050 0f, or c0050 18?
If so which one?
Old 10-29-2017 | 09:34 AM
Wires maybe ok but the pin connection may not be. And a hint, disconnect the negative terminal on the battery before you check the pins
questionMARK
10-21-2016 02:27 PM
ald
06-02-2016 12:17 AM
rjdelapp
07-26-2012 10:56 AM
helhedded
03-22-2012 06:55 AM
brdiver
03-02-2012 09:57 AM
Quick Reply: ABS and Tc light on
