ABS and Traction Control Lights
GMpartsdirect.com or any of the GM parts sites should lead you to a part number. However, be prepared for sticker shock! That type of pigtail usually is in the $40-$80 range.
Which side is messed up? If it's the wheel side you would be better off replacing the hub, They can be had for around $40 on eBay.
