AC draining in passenger floor board 07
Hello other HHR drivers.
I am looking for a picture of where the drain hose will be located on the back of the front right tire. The car keeps filling up with water. I changed the cabin filter that was clogged but now car ac is draining inside car and making a mess.
Welcome. Here's a post that describes it. I'm sure 843 won't mind me borrowing his post.
https://www.chevyhhr.net/forums/show...16&postcount=2
i have a picture of the condensate drain tube in my profile picture. Pretty sure my heater core is leaking. You can see the drain tube if you look from the drivers side with a flashlight and look towards the passenger side on the firewall. The picture I took is from underneath the car however.
Welcome to the site.
Did you read this whole thread ? There is a link in post #2. Pretty much all the info needed is covered.
If you need any more info, try the Search function. There have been several different threads about clogged AC drains.
