AC intermittant
Old 05-12-2012 | 12:23 PM
gmzimmer's Avatar
AC intermittant
I have a 2007, LT1, 2.4 with 63K. The AC has started to run cold intermittently. Sometimes I have to turn it off and on repeatedly, then it will work OK until I shut it off. Is it likely a switch? sensor? in need of a recharge? Any suggestions will be appreciated.
Old 05-12-2012 | 03:27 PM
https://www.chevyhhr.net/forums/problems-service-repairs-42/need-some-help-w-ac-not-working-properly-40760/
Try this.
Old 05-12-2012 | 03:28 PM
Honestly I could be any one of those things, but you'll need to try and eliminate some things during the diagnostic process.
The first thing to check is your coolant level, if its low, you'll get some out of range signals form the temperature sensor which can affect compressor engagement. Also pay close attention to you engine temperature, is it running consistently high, or low.
If the cooling system checks out, then you have to look at the switch module in the dash and even consider taking it to an A/C shop to see if the system is low on charge.
We had a member last week with a low charge and similar symptoms to yours.
**Thanks for the link in your post George, you have quick fingers man.
Old 05-14-2012 | 09:38 AM
gmzimmer's Avatar
AC Intermittent
Thanks for all of the advice. I will investigate and post the results
got2boostit2
09-21-2013 06:33 AM
galtjunk
68
09-11-2013 04:58 PM
pitbull76
28
12-10-2012 03:00 PM
vacarman02
10-15-2010 05:18 PM
CarlsSS
11-01-2008 09:00 PM
Quick Reply: AC intermittant
