Ac only blows cold while car is moving
Old 09-17-2018 | 01:25 PM
jollymon's Avatar
Hey y'all had to replace my Blower Fan in a 2007 HHR LT 2.4 because of water damage . Have fixed all leaks and Blown out AC Drain .
Blower Fan works great but Cold Air only comes out while Car is Moving ( Did not do this before Blower Fan went out )
I did move the HEATING & AIR CONDITIONING BLOWER MOTOR RESISTOR while removing the BLOWER MOTOR and replaced it .
Could this Part be the Problem ?
I have read comments on the : AC DIODE , AC CLUTCH RELAY #15 and FAN .....
Everything was working fine until the BLOWER MOTOR went out and was replaced .....
Any Ideas or Suggestions y'all ?
Thanks !
Old 09-17-2018 | 01:42 PM
Did you hook the fan wires up in the correct polarity? I seem to remember some "fits all" fans blow backwards. Take the glove box door off and check in the filter to see if it is blowing "up" or :down".
Old 09-17-2018 | 04:18 PM
jollymon's Avatar
Blower Motor ... Chilled Air
Hey Blower Motor works great ... Just no Chilled air until Car is in Motion ...
Jlogudce
03-04-2018 06:37 PM
deb55
06-21-2017 09:15 PM
hoksab
07-15-2016 10:05 PM
cosmic1
10-14-2013 06:03 PM
ZTony8
11-03-2011 09:44 PM
Quick Reply: Ac only blows cold while car is moving
