Which actuator do I need to replace?
I noticed my A/C wasn’t blowing cold air evenly through the vents. It turns out there’s about a 10 degree difference between the passenger and Driver’s side vents. The Driver’s side vents being the warmer of the two. I started researching and found out it’s probably a bad actuator, but I don’t know which one. It looks like there are 2 actuators? Both on the passenger’s side of the dash. I’ve found one is called the Blend door actuator that regulates heat and cold, but I don’t know what the other actuator is cold. I’m assuming based on my problems, that the blend door actuator needs to be replaced. Is this correct? Can anyone explain the two actuators to me and which one might be causing my issues?
thanks!
thanks!
From the library
https://www.google.ca/search?q=2007+...&client=safari
there is one above the glove box on the passenger side, one above the radio on the drivers side , need to determine which one, do you hear any clicking? Like the door won’t close?
From the library
There are 3 actuators. If I had to guess, I would think that the mode actuator would be most likely to present with the symptoms you are describing.
You may also look to see if the duct to the driver side has come loose or is damaged, allowing the cold air to escape, and the warmer cabin air to enter.
ill check to see if maybe there’s a hole in the vents somewhere. The only thing I can think with the actuator is it’s not closing off properly which is allowing warm air to come through the drivers side vents.
Only bring this up because I just went through a similar issue on a new home HVAC system. Found a duct that was attached to the new unit had become dislodged. Was still getting air to blow thru but was sucking in that hot attic air.
A temp difference between vents. I would suspect the vent that is blowing warmer has a leak or partial disconnect on that duct work. A leak there would allow under dash, warmer air to be sucked into that duct for that vent. A long shot but something to look at.
