air bag?
air bag defect - is unlikely.
Most of all - a temporary loss of contact within the electrical network.
This may be connectors of seat belts. They suffer most because are "underfoot", in addition - the danger of getting wet. Another - connector control module air bag may pose a problem.
The control module airbag is located between the front seats. Under a plastic panel (with cupholders). This is the only connector that can be easily tested. Just dismantle the plastic cover, a visual inspection (dust, moisture), disconnect the connector and plug the connector again.
If the problem persists - a visit to a professional car electrician. The remaining connectors and parts are difficult, not recommended for home repairs in the garage.
