Air bag light
Old 03-21-2011 | 03:28 PM
Bilcar's Avatar
Air bag light
Just turned 36k and the "service air bag" light has been showing up, goes off and will came back on. Any ideas? Thanks! Bil
Old 03-21-2011 | 03:43 PM
Dealer - warranty! You do not want to mess around with airbags.
Old 03-23-2011 | 11:43 AM
Gas Man's Avatar
There is a new TSB on that issue.
Are you placing your cell phone, GPS, laptop, mp3 player on your passenger seat???
If so DON'T, that is causing the problem!
I **** you not, my dealer was talking about it yesterday.
Old 03-23-2011 | 12:10 PM
BlackknighT's Avatar
Mine just went off Monday morning for about 15 minutes steady, then on and off for about another 15, then out. Light & DIC went on when I used Auto Start & hadn't even gotten in the vehicle yet. Tuesday used the vehicle without Auto Start-no issue. Low & behold, this morning used Auto Start & the same thing as Monday but was steady for about 30min then went out the rest of my hour long trip. I made an appointment to have it looked at.
I checked under seat wiring-nothing loose or disconnected. Checked car seat cover straps-hooked onto metal loops under the seat-no interfearance to Air Bag wiring on either seat. I have nothing hooked up to 12volt sockets. No issue with passanger-didn't have one either time. Light on passanger side remained at off.
Old 03-23-2011 | 12:14 PM
urbexHHR's Avatar
Is it the weight from the devices or something electronic?
Old 03-23-2011 | 12:21 PM
Gas Man's Avatar
it's not weight, it's electronic interference. They don't have to be plugged in or turned on to cause problems. The problems can vary from nothing, to airbag fault light, to airbag on (as if someone is sitting there), and/or ding because nobody has buckled up as well.
Old 03-23-2011 | 12:22 PM
The listing I see deals with voltage/current/electronic interference. Weight on the passanger seat is a different issue dealing with weight sensativity, not electronic interference.
I am hoping mine is as simple as the wires attached to the wheel bag are shorting against the plate inside the steering wheel. The dealer can pull codes that should pinpoint the issue. The codes stay in the memory for about 49 start/stop (key on/key off) cycles.
SORRY GAS MAN-I wasn't fast enough-beat me to it....
Old 03-23-2011 | 12:39 PM
urbexHHR's Avatar
Just as long as I don't set it down and the airbag goes off!
Old 03-23-2011 | 02:00 PM
Bilcar's Avatar
I take it to the shop Thur afternoon.... will let you know what they find.
Old 03-23-2011 | 08:54 PM
87silver's Avatar
Couldn't find any related to microwaves or EMI. The only one to date is below. If you find a new one, please post. Thx...
Nature of Defect:
AIR BAGS
Bulletin Number:
TB-080941006
Bulletin Date:
Apr 2009
Summary:
GENERAL MOTORS: THE SIR LIGHT IS ILLUMINATED. DTC B0081 PASSENGER PRESENCE SYSTEM (PPS) CODE STORED (INSPECT PPS SYSTEM CONNECTORS). ( NHTSA ITEM NUMBER - 10030104 )
Quick Reply: Air bag light
