Alot of issues: please help
Old 06-18-2020 | 12:17 PM
Originally Posted by TheBurgCatcher
thanks Oldblue, happy to be here!
i have inspected the Underwood panel I removed the upper and dusted out the 2 halves.. Once I removed the upper I noticed the rear threaded power supply has a crack in the eyelet.. I’ll try sourcing a better undamaged one.. ( can’t hurt)
I don’t believe it has any prior water damage..
I may try having the computer flashed..
the ODO is also only reading that the car has 54 miles on it??
The rear red wire is for the power steering. Make sure you have tightened the bolts for the fuse block halves completely. They seem to get tight, but they may need to be turned some more.
Old 06-18-2020 | 05:22 PM
I hope it was a great deal since it doesn't run and has no electrical system. it is illegal to sell a car with a broken Odometer, which leads me to ask; was this a stolen car? Got a title?. That is my definition of a POS.
Exactly why do you think flashing any of the computers would help? Do you have free access to Tis2web and a scanner?
The only thing that stands out to me is the code for the current sensor. Kind of like somebody hooked the battery up backwards.
The B3006 02 means the hood ajar switch is shorted to ground. That is actually 2 switches, 1 is "hood open" the other is "hood not closed"; when one is in the open state the other should be in the opposite state; if both are low then 02 if both are high then 01.
The relays being stuck adds credence to polarity problems since most of them are triggered by a ground signal.
Old 06-18-2020 | 06:08 PM
Hello fellow HHRers, i recently purchased an 08 LS panel and its lit up like a tree...
- the running lights/ flashers are stuck on (even when i remove the flasher button)
-the headlights are always on..
-door lock button wont work ( I've ordered a replacement key fob hoping they work with that
also the rear door pop buttons and rear hatch buttons wont work
Running lights are not on the flasher circuit. So are the running lights flashing, or just all the turn signal bulbs? Is it 24/7, or only with the key on? Same with headlights, 24/7?
When you are talking about buttons not working, do you mean on the fob, or the buttons in the car? Both?
Old 06-19-2020 | 04:04 PM
TheBurgCatcher's Avatar
it’s all tightened up good.. I took it all apart and cleaned everything to make sure it has good contact
Old 06-19-2020 | 04:10 PM
it actually runs great.. just has the few electrical issues that I’m sure will be sorted..
its does have a clean title and is a 1 owner car.. they just used it as a work vehicle.
yes I do have access to have the car scanned and flashed for free
ill check the hood switch or change it out to see if that clears at least one thing out.
Old 06-19-2020 | 04:31 PM
I mentioned the hood switch because several other systems are demonstrating short to ground symptoms, like somebody hooked the battery up backwards or somehow reversed polarity.
Old 06-19-2020 | 06:38 PM
Now we’re getting somewhere! Let us know after they are done!
Old 06-19-2020 | 07:38 PM
1 owner car... So did you buy it from the original owner, or a used car lot? I guess it doesn't matter, either one could have done some hack work on it. If original owner, maybe could give some history. Accident, ran over debris in road, etc.
Old 06-19-2020 | 09:12 PM
B3950 02 means the left rear turn signal is shorted to ground, meaning that it is feeding B+ to the ground plane. Are there any LED lights involved?
Under your list of current codes none of the U and C codes exist in a HHR, but they all site a short All of the others call for some short circuit or wrong voltage.
You should check fuse #24 on the BCM. That is a possible cause for B1517, that and a bad charging system.
Old 06-19-2020 | 09:16 PM
You should check fuse #24 on the BCM. That is a possible cause for B151, that and a bad charging system.
ill take sometime tomorrow to look into these things.
so far thank you everyone for all the help!!
Quick Reply: Alot of issues: please help
