Another 2006 Not Starting
Hey all, I drive a 2006 HHR and we've had numerous incidents in the past with trying to get it to start. We've done the security lockout procedure before and it worked quite well to get me from Eureka back to Lawrence. But now that I'm here, its decided to give me a fuss again. Here are the current symptoms:
- Not turning over
- Showing engine light
- Showed "Power Steering" across message board
If it was a security lockout the lockout light would be on. That does happen with a dead battery, not a weak battery.
I don't know what you think the security lockout procedure is, but look in your Owner Manual to find that it is simply re inserting the key and turning it on.
Link to Owner Manual in my sig.
Sounds like a neutral safety switch or clutch pedal position sensor problem.
https://www.chevyhhr.net/forums/prob...-issues-50825/
LennyLaPolla
02-16-2016 05:27 PM
bculberson
03-19-2011 06:51 PM
